Quentin,
In the top photo the tracks fit inside the hopper, the operator drives over the load, then positions himself as you see, and empties the car, in this photo, the one ahead of him or to the right.
Then he backs up over the load behind, positions himself between the next two cars, and starts over.
The back hoe has enough reach to go all the way from one end of the car to the other, and the weight in the bucket is small compared to the weight of the back hoe, no worries about it being unstable.
This guy was good at it, and kept the dump trucks moving quite quick.
There is a dirt ramp at the end of the cut of cars so he can drive up on the car
If you look closely, you can see another cut of cars behind the ones in the top photo, he was reaching into them also and cleaning them out, doing two tracks side by side at one time.
This was at a “mobile” concrete plant, they were mixing the concrete for the expansion of IH 10, (Katy freeway) about a mile away from the location of the plant.
About a month after this photo, they moved the entire operation west about 10 miles to another field, laid down two sets of panel tracks and a run around off of the old SP Hearn line, they cut into a siding, installed a switch, and in about 3 days were up and running again.
The concrete mixer and all of the assorted equipment had truck frames and braces, along with axels with freeway tires and they could lay it down, hook up to tractor trailer rigs, (18 wheelers) and move out in less than a day, really an impressive operation.
When they arrived at the new location, they had the mixing tower and other parts standing up in the same day they arrived on…the tower and mixer were several stories tall, pretty slick set up.
They make up the dry mix, and add the aggregate and water at the last minute in the cement trucks…this stuff is still mixing when it arrives on the pour site.
Tdot leased several fields from farmers along the I 10 cor
