I have a few old Williams passenger cars that have had the window strips fall off inside the car–the glue let go.
What type of glue should I use to reattach the window strips? I don’t think I should use CA (super glue) as that would probably fog up the window strips to the point of ruining their appearance.
I was thinking of using Elmer’s glue (white glue) but I’m not sure it’s strong enough.
Would “canopy glue” that is used for model airplane kits be the best choice?
Have you actually used that to reattach window strips? There’s too much could go wrong, IMO, including possible damage to the passenger silhouettes, gluing your fingers to the plastic, and making it very difficult to remove the strips should that become necessary. Formula 560 and Aileens are water based, much less opportunity for disaster.
I had to replace window strips on a set of sheet metal passenger cars last week. I used masking tape to hold the windows in place; a 1/4" strip above and below the glazing works fine. It doesn’t damage the finish either.
