Will F-units make a comeback?
From another thread here, there are many shortlines that still use F-units for freight. One reason why they disappeared from Class 1s is that the engineer couldn’t see backwards that well. But know, most big power isn’t mean’t to be run long hood forward anymore. So is there a slight possibility that the F-unit shape will come back?
The F-unit shape ‘came back’ in the form of ‘cowl’ units - full-width cosmetic carbodies on switcher-style frames.
The key difference between the original covered wagons and the later full-width carbody types was that in the earlier form the sides were structural trusses that supported the frame to prevent sag. Returning to that design is, to put it mildly, improbable.
The one big advantage of the narrow hood, absent in the full-width body, is the ability to open a couple of doors and have easy maintenance access from a built-in, easily accessible platform which leaves ‘wiggle room’ between rails and stanchions. With a solid car side, that wiggle room isn’t there.
Chuck
The ‘F’ has a trussed car body - it costs more to build than a road switcher type of unit(sheet metal hood over the engine that is mounted to rather heavy-duty frame rails). EMD figured this out with the GP7, and sold them for less than an equivalent F7. It did not take the railroads long to figure out that a GP would do everything that a F can, and cost less!
Maintenance with an F requires pulling the prime mover out of the car body. A power assembly can be pulled from a GP with the side access doors opened. When access is simple, things get fixed faster and there are less road failures.
Jim
Keep in mind taking a cue from the automotive side of the house GM offered trade-in values on the F units in an attempt to keep moving product, which is why a lot of 'roads were happy to trade in their F units on new Geeps and SD’s. Some 'roads didn’t, which is why there’s still some F units out there, otherwise they’d be darn near extinct.
With a defference to Posters Chuck and Jim and Firelock:
There comes a story like this from TRAINSNewswire of December 21,2012: as follows FTA:
"Norfolk Southern acquires additional F-units"By Chris Guss
Published: December 21, 2012
5004612691_722f264a5b_z
Two of the current NS F-units on a ferry move at Marion, Ohio, on Sept. 18, 2010.
Photo by Brian Schmidt
FTA:"…CHICAGO – Norfolk Southern has acquired an additional three F7 locomotives. The three units are located at two National Railway Equipment facilities in the Midwest. Former Canadian National EMD F7A No. 9177 is located at NRE Dixmoor, Ill. Two additional units, former Coe Rail F7A No. 407 and former Canadian Pacific F7B No. 1019 are reportedly at NRE’s Mt. Vernon. Ill., Facility. No. 9177 has reportedly been relettere
Correct me if I’m wrong but aren’t modern passenger diesels which use monocoque style carbodies somewhat similiar to F units? I know the body shell is stressed in such designs but IINM the shell can be lifted off to service the machinery…
No surprise NS bought some more F’s. They may be old, but they ARE cool, and they provide a classic head end to their office trains with (probably) a minimum of maintanance headaches.
If NS wanted to make a Splash they should see about getting say the last PS-4 and returning her to Steam.
Oh, the last PS-4. That one’s safely ensconced (or entombed, if you will) in the Smithsonian Institution in Washington. It’s NEVER coming out again, it’d be way too much trouble and horrendously expensive to get it out of the building, through the city and on rails again.
It is in oustanding condition, however. Still, I suppose life stuffed and mounted in a museum is better than no life at all. It would be a lot easier for NS fo find/borrow a USRA Pacific type and return it to operation as a substitute PS-4. I wouldn’t hold my breath on that one.
Interesting, aviation fans like myself puzzle over this question, similar to railfans and their favorite locomotives : If an airplane doesn’t survive to fly, is it really surviving at all? No easy answer to that one.
Yes there are, but I’m more thinking of the classic bulldog style front.
I would love to see the F units make a comeback similar to how the Norfolk southern did theres. One great thing about F units is they are wonderful in the winter. Anyone who has tried to get into a locomotive with 2-3 feet of snow on the walkways, along with the frozen doors knows what I am talking about. I think thats why the cowl units in Canada are still going strong. They also make for great snow plowing duty especially the F units. I also think the F units make for a very comfortable ride with a huge cab
The modern passenger locomotives have certainly brought the F units back into a more positive view with the engineers. I know one of the biggest problems with the F units was the engineers complaining about how they had to climb up all those steps with their bags. But the Amtrak locomotives are no different now.
One thing I’ve read about engineers and the F units, and E units too for that matter, is that veteran steam engineers were a bit nervous about being up front without 50-plus feet of steel between them and a possible collision. They were a lot more comfortable in the Geeps with the long nose, or even short nose forward. Modern day engineers aren’t bothered by that (I think) not having known anything else.
F-units were great if the railroad only wanted to use them on mainline trains where switching wasn’t an issue. Erie Mining’s F9s lasted so long because they hooked up to a taconite train and pulled it to the shore of Lake Superior, then pulled the train over the ore dock (which was built parallel to the shore and was double ended) and thru a reverse loop, then pulled the same empty cars back. No switching required, plus the enclosed carbody might have had some advantages in Minnesota’s harsh weather.
But, if a railroad bought F’s, they had to also buy GPs or SDs to do road switcher work. At some point, someone figured, why buy single-purpose F units when we can use a GP as a passenger engine, mainline freight engine, road freight engine, or yard switcher??
It doesn’t really have to do with ‘long hood forward’, many railroads bought early road switchers set up to run short hood forward.
In a GP or SD or similar road switcher, the engineer has a window in front of him, and a window in back of him. In an F unit, the engineer has a window in front of him, and the cab’s back wall in back of him. Unless he leans out the window (or had a rear-view mirror) he has no rear vision. Looking back along the long hood of an SD-90 might not give you great rear visibility, but it’s better than none.
If the plane in question is something like the Hughes Hercules flying boat or the XB-70 Valkyre preserved at the Air force Museum than Yes, they do survive…
There is no practical path to make either of those examples airworthy but to scrap them would be historical sacrilege.
This is also the case with some notable locomotives…
To carnej1: No disagreement with you there, my friend!
Wonderful subject for old hogheads, like me, who at 20 yrs old hired out when the cab units were middle aged, at best, and old and doddering, typically.
Some of the rebuilds, the seudo-F9’s in the 600 series on SP, had a foot long, approx’, extensions welded to the throttle so that when backing we could easily find it. Even with the peg-leg an engr I fired for had to kneel on the cab floor and I watched as he looked back for the brakeman’s signals, then flailed to find the controls which were behind his back while kneeling.
At 6’2" I didn’t have that problem with those engines but backing with the standard throttle of most of the Black Widows challenged…
And these desk equipped control stand engines…until during one of the turn-of-the-century’s trips, I’d decided when I wanted to pass an Absolute Stop signal without authorization from some controller…but, looking forward in responce to a brakeman I followed his hand signal…and went by one… my and the engine’s design’s fault.
If your signal giver is riding on the right-side front engine step to see the signal giver you look into the big combo wind-deflector (for forward moves) at the cab side window but…in it you look for the image of the signal giver in a small image reflected from the little mirror reflecting their location and gestures from the low front steps…got it?
I’m watching these hand signals and see this red absolute signal go by while the person I’m taking hand signals from limply rides the front step;.I got away with it and unfortunitaly could not demand that i could simultaneousely see ahead and a couple of reflected and re- reflected images.
Did I emphasize that rule req
BTW I don’t know that that is really true. There may be a couple of shortlines using F-units on freights, and there are several that have F-units for like dinner trains where the F-unit might occassionally be used to move freight. But the number of F-units in everyday use in freight is miniscule I suspect.
It may be a little bit like steam in the sixties. In 1964 maybe 1% (or less) of the US’ locomotives were still steam. But railfans loved steam, so magazines like Trains often had stories on tiny shortlines or industrial railroads still using steam. If you look at the old mags, it would make you think steam was still quite common, since there were so many stories on them. But in reality it wasn’t the case at all.
I lived by two gentlemen who started back in the days of steam with the NYC. When the F units arrived they told me they hated them. Visibility was bad, switch work was hard due to a lack of both forward and backward visibility. Getting in and out of them was hard and had to watch your head when going through the door. Sun glare off the windshield would occur at times. Took three locomotives to do the work of one steamer. Got to a point I was sorry I asked.
But they did agree, they looked good. The one gentleman, Jim, said that was why Lionel liked them so much.
As for me sitting trackside, never met and E or F I didn’t like.
This linked photo is off the NS Fan (Facebook) site:
It is the CN 9177 now Sou 9177 @ NRE at Dixmoor,Il. (not my photo[sigh])
http://sphotos-a.xx.fbcdn.net/hphotos-ash3/13691_10151214751794315_1140622265_n.jpg
Firelock, part of that PS-4 made it out for a little while about forty years ago. When the 4501 was in the Washington area in the late sixties, the PS-4’s whistle was mounted on the Mikado and a recording made of the Mikado as it came into and left a station. In 1974, I heard the recording while standing by the Pacific (I haven’t been back to the museum since then).
