Will UP ever restore its Gas-turbine locomotive?
Will UP ever be able to restore the Gas turbine locomotive?
Highly unlikely. Even in their prime, the various GTEL’s were oddballs on an overwhelmingly diesel (and some steam) roster. Parts availability for the prime movers would be virtually impossible and the support staff would need some A&P-certified mechanics to help keep it running.
Isn’t this really two questions: Will UP bring back its old style of GTEL, or will UP use turbine power in the future? Note: I am assuming you don’t mean whether UP will restore a Big Blow to go with the Big Boy, or to doublehead with the Centennial, or whatever. That question would need to be posted in the Steam and Preservation thread.
The answer to the former has really already been answered. To add to what he said, the economics depended on a very cheap fuel, which ceased to be cheap in the late '50s. If Jerry Pier sees this thread he can comment extensively on this and the other factors involved with these locomotives.
There is probably some application for turbine power on UP in future, but it would have to be very different from the historical GTELs (perhaps using a number of smaller ceramic turbines, and including substantial bottoming heat recovery making them in essence small GTCC plants). Whether there are advantages to that, vs. modified positive-displacement piston engines making the same effective hp, remains to be seen; personally, I think the turbines may be a better solution for high horsepower if burning LNG or CNG. But do not expect those locomotives to be Bigger Blows!
Comments by Jerry Pier would be a welcome addition here. His unique insite would add much.
With the current regulatory stance by the Federal Government ( essentially, anti- Coal power) in Power production?
Along with the current testing underway on LNG Applications for Railroad locomotives. It would seem that Turbine applications would be an economic benefit(?) possibly, a good alternative to the conversion of Diesel Power to mixed fuels( engines started on diesel and then LNG for operations?) on the Railroad.
Around this area there seem to have been a few applications in the stand-by Electrical Generation Facilities for Turbine type generator power plants. MAYBE THESE ARE JUST USED TO HELP IN PEAK POWER DEMAND SITUATIONS? <
Much better to use its manpower to restoring currently out of service diesels. ie more HP per buck. Also the fuel guzzling turbines do not work well on up and down profiles. Much more miles per gallon on a diesel or maybe a LNG loco. Note what happened to the NY state turbo liners
When I worked for Northern Canada Power at Whitehorse Rapids GS back in the 70’s we had a couple of gas turbine package units in standby service at Faro, YT (Anvil Mine) on the far end of the 138kv line. They supplemented the existing standby Diesel plant.
I never ran them but according to the Faro operator and others they were noisy, dirty and inefficient. Like wise, they were hard to maintain I was told. IIRC they didn’t last long. The diesel on the other hand is still there I believe.
Charlie
Chilliwack, BC
The killer issue for gas turbines as prime movers in locomotives is fuel efficiency at low output (high turndown). Diesel engines are the preferred prime movers because of relatively high efficiency at all output levels, especially if the prime mover speed is allowed to vary with power output (true of almost all locomotive applications).
To put things in perspective, the 4500HP GTEL’s and the SD70/AC4400’s produce are roughly equivalent in power. The GTEL’s consumed 450 gallons per hour at full throttle and 200 gallons per hour at idle. The modern diesel consume a bit over 200 gallons per hour at full throttle. OTOH, the GTEL’s used 1950 era gas turbine technology, advances in turbine materials allowing higher turbine inlet temperatures and computational fluid dynamics leading to improved compressor design have led to a factor of two or so improvement in efficiency. Some simple cycle as turbines are more efficient at full output than a 1950’s era diesel engine.
What may make sense is a gas turbine battery hybrid, where the lighter weight of the gas turbine would allow for a much larger battery than possible with a diesel engine of equivalent power. Ideally the battery should be large enough to allow store at least 1 to 2 hours of the gas turbine’s power to allow the turbine to run out at full power (most efficient) and reduce the number of starts (extends the life of the turbine).
Allison was experimenting with steam injection to improve efficiency and reduce NOx using exhaust heat to generate the steam. This could be of help in reducing the exhaust temperatures.
  • Erik
I believe they have their hands full with 4014 for the foreseeable future. Nobody knows how much that is going to cost and UP does have a bottom line to consider. There is only so much they can spend on museum pieces
We may be on to something here:
given that a gas turbine’s fuel efficiency improves with heavier load, a hybrid locomotive with a battery charging generator powered by a g.t. that would operate at full load when, but not until, the battery needed charging and, I guess, would fire up to supplement the batteries when very high locomotive horsepower was called for, might be possible…feasible?..practical?
erikem, I realize I restated your concept, full credit to you; my tech flourishes didn’t “ruffle” your “feathers,” hopefully.
Putting it simply, a restored gas turbine locomotive won’t excite the general public the way a restored steam locomotive will. Railfans yes, but the general public who (no insult intended) couldn’t tell a gas turbine from an SD70, no.
Exciting the public’s what a steam program’s all about.
Consider my feathers unruffled… [:)]
I was pleased that you thought the idea had merit. A couple of places where it could make sense, one being an area as southern California where air pollution is a major concern, a gas turbine burning natural gas is bound to be cleaner than a diesel. The other would be a line with a long tunnel, e.g. Cascade tunnel or Moffat tunnel, where the turbine would be shut down during passage through the tunnel.
The gas turbine hybrid might be even more efficient than a diesel on a hilly route, where the regenerated power while braking could be put to use later. This was (is?) the impetus behind GE’s hybrid locomotive, though the larger battery capacity possible with a gas turbine prime mover might make the concept even more attractive (full power out for maybe 2 hours with the turbine, half power output for one hour with the diesel).
Feasibility? Biggest obstacle is the battery, with the GE battery being my guess as the best choice (strong emphasis on guess).
  • Erik
Well, the turbine would be just a little bit louder…
Why are we talking about things like fuel efficiency and their oddball status? Isn’t the topic about restoring one of the Big Blows to operation for special occasions like the steamers?
Uniqueness and fuel cost shouldn’t be entering the equation if I’m understanding the topic correctly since it would be only for special events. What matters most are the condition of the survivors (Two, if I’m not mistaken), their completeness such as if they still have their turbine and generators, the ability to maintain one in running condition after restoration such as parts for their Cooper Bessemer engine, its suitability for use, and its potential PR value.
Sadly, we all know it’s a moot point even if one of the pair was in excellent condition, the major appliances were able to be reasonably maintained, they could easily burn diesel like the rest of UP’s fleet including the two operating steamers, etc. Union Pacific never held these with the fondness that they did their late model steam or their DD40AX’s and weren’t responsible for saving the two that ended up preserved.
Why would they care now especially with their ambitious plan to restore the 4014?
Excellent post although one could argue that the general public wouldn’t be able to tell the 4014 apart from the 3985 yet that’s happening just the same.
But hard to twist a long forgotten gas turbine locomotive as having any sort of impact like the Big Boy program already has enjoyed these first few months. That tops the list of many reasons why one will never turn a wheel under its own power again.
The UP “Big Blows” used industrial gas turbines that were not particularly well suited to moving platforms.Gas turbines following areospace designs are better suited to portable use; easy start and stop, lighter weight, etc. Having said that, fuel cost is the problem that has to be solved. Recuperation, a well established technique, goes a long way in solving this problem. (Turbomeca developed an 1800 hp recuperated unit before they got out of the locomotive power field in 2005.) Use of LNG as a fuel also has a good potential to reduce fuel cost as well as enissions. A new locomotive design would be lighter in weight, saving more fuel. The Big Blows had problems with lead locomotive exhaust starving trailer units for air. This could be overcome with high density power on the front end and better tunnel ventilation. The easy start configuration would make it possible to shut the power turbines down while going down a long slope, using auxilary power for dynamic brake exitation, thus saving more fuel.
Unfortunately all of this tends to be academic since there is little incentive for existing locomotive builders to abandon a fully amortised design. A government or industry incentive to reduce oil consumption (railroads use aroung 4 million gallons/year) as well as emission limitations could re-awake this sleeping giant but I’m not holding my breath.
I’ve written a dozen or so published papers on the subject, including a comprehensive history, none of which have made much of a dent.
To get an idea of recent gas turbines, we can look at the M1 Abrams tank and the Honeywell AGT 1500 which powers it. This 1500 horsepower engine requires nearly 10 gallons of fuel to start and 10 gallons per hour at idle. Running cross-country consumes 60 gallons per hour, but normal operation is around 30 gallons per hour. The engine has been very reliable on about 9000 Abrams tanks and can consume a multitude of fuels including diesel, kerosene, gasoline, and jet fuel. Put three of these together on a locomotive would give you the equivalent horsepower of the old UP gas turbines. However, the fuel consumption is still considered high and Honeywell and GE have teamed together to produce the LV100-5 as a direct replacement in the present Army’s PROSE program. It is said to be quieter, lighter and smaller with 43% fewer parts. Fuel consumption is down to 5 gallons per hour at idle and down 33% at power, which should put cross-country consumption at about 40 gallons per hour. Reliability assessment will have to wait for actual operation in the field.
It wouldn’t be that expensive to dieselize one. Sort of a cosmetic resroration but I agree steam is something the general public sees as different. Another yellow blob won’t excite them.
It would be more expensive to dieselize one than to buy a new diesel or they would have done it to the fleet and not scrapped the bunch. But of course when the scrapped it they saved all parts that could be used to maintain diesels or build new ones. Traction motores, trucks, blowers, probably even filters and the cab seats.
Interesting idea! How about two or three small gas turbines to better fit part throttle operation?
Something akin to the “lets make a GG1 move again” threads that have been around. I agree with you that the general public sees things as “steam” and “not steam”. Just today I read an newspaper article where the NS steam train into Danville KY was described as having a “lonely whistle”.
A yellow blob would never have a “lonely whistle”…
"But I shot a man in Reno . . . just to watch him die
When I hear that whistle blowin’ . . . I hang my head and cry"
http://www.azlyrics.com/lyrics/johnnycash/folsomprisonblues.html
