The wind sock is a requirement by OSHA for any facility that stores or uses any hazardous material that can be or is a gas, or may form a vapor cloud if released to atmosphere.
Your freezer plant qualifies in this regard.
Freon is not very efficient for large volume freezing…Ammonia is.
To achieve the same efficiency as ammonia, you would have to compress the Freon upwards of 1/3 more than what your home freezer does, and have an expensive adjustable expansion valve in your heat exchanger.
Ammonia does the same job on a larger volume cheaper.
The main reason Freon is used in your refrigerator is safety.
Your freezer uses Freon compressed to a high pressure and is then used in a relative small area (the freezer) before being recycled through another expansion valve to the refrigerator, and finally compressed again, starting the cycle over.
In a home A/C unit, Freon on average can only “cool” the air by approximately 20 degree below the ambient temperature.
In excellent insulated homes, you can get close to 25 degrees.
Theoretically, A/C units and freezers/refrigerators are permanently sealed systems that should never need to be recharged; the “coolant” never wears out so to speak.
All you are doing is compressing it to a liquid, then forcing it through a valve into a gas…it never gets contaminated or used up.
In reality, most systems, as they age, will develop very small leaks or require repairs…small amounts of Freon in your home atmosphere are harmless, ammonia on the other hand…
As Randy pointed out, propane can be used, as can natural gas…almost any compressed liquid, even water, will “cool” as it expands into a gas, some are more efficient than others.
In fact, the first home refrigerators used natural gas, propane or ammonia.
But then again, they didn’t require seat belts in cars back then either.
