Wiring Peco Switch Machine on Peco Turnout
When it comes to wiring I am an illiterate and have 6 PECO turnouts to wire.
I have on hand a 17V DC and 20V AC transformer, Peco PL-10 turnout motors, and a Peco CDU as well as terminal strips and SPDT momentary toggle switches.
The wiring diagram with the CDU looks like it uses a buss type wiring plan but I think this is an over simplification. I want to use the strips to eliminate soldering.
Please give me some suggestions or better yet a thread (I searched) or web site showing a wiring diagram that a newbie like me can read.
Thanks,
Bob
Here’s the wiring diagram on the instruction sheet that comes with the PL-10W motor:
Please keep in mind that this diagram shows the wiring to the motor only, if you have Electrofrog turnouts you need a PL-13 switch (or similar) to control the polarity of the frog.
Svein
Bob,
This may be overkill but hopefully will help. I found installation to require more precision than I anticipated and had to re-install my Peco to eliminate binding. I detailed the installation procedure that worked for me per below. I soldered the spade lugs that will connect to the terminal strip, but you don’t have to.
My subroadbed is 50" above the floor at this point, so I found access to the motor underneath for the install challenging at best. Replacing Peco’s screws with Phillips and getting a long-shank #1 Phillips screwdriver was critical to my sanity, as was using an assistant to flip the points to make sure there’s absolutely, positively no binding.
  1. Prepare (2) 3-layer pieces of .015 x .250 styrene strip, (1) positioned outside each point rail. This holds the points in dead center.
  2. Drop a length of 3/64 brass rod, prepared with a 90-degree bend at one end, through the hole in the turnout’s throw bar. This indicates dead center when working underneath.
  3. Cut shirt cardboard to fit the bottom of the turnout motor & punch a hole dead center for the actuator rod. This will center the rod and provide a place to start with the centered turnout points. Remove this template once the machine is initially positioned, as the actuator rod needs to move freely when checking for binding (see below).
  4. I then marked the centerline of the throw rod by extending a line from each end with pencil to the edge of the subroadbed, “wrapping it around” the thickness of the plywood, and connecting the points underneath. The line should bisect the actuator hole. Alternatively, one can drill a 1/16 hole through the subroadbed at each end of the centered throw rod and connect the points underneath. (Can also drop thin wire through these holes and connect those underneath).
  5. Next, strip 1” of 22 AWG wire to solder to the Green and Yellow positions on the right side of the motor and the bridged black positions on
Hi Svien and Rick,
Svein,
Your post answered some questions but raised others.
I had planned on using the DC side of the transformer and I see that is wrong, it should be AC. Does that mean the momentary contact switch is incorrect also? I seemed to remember reading somewhere that if you used a CUD momentary toggle switches aren’t necessaty. Do you have any ideas about that
Now this is where I get lost. Where do I put the terminal strip(s) and how are they wired for more than one motor?
I am using insulfrogs.
Rick,
I’m still studying the wiring. Your pictures really help.
As for the positioning of the switch motor I don’t have that to worry about since I’m using Peco motors which attach directly to the turnout. The info will certainly be useful if I use any other below
I have found that instead of soldering the wires to the Peco switch machine, I solder Atlas rail joiners to the ends of the hookup wire. The Atlas railjoiners slip right on to the switch machine terminals with a tight fit enableing easy removal in case the switch machine has to be replaced
Hi Bob,
I don’t know if the Peco turnout motors work with DC, maybe they will, but Peco recommends 16V AC. I’m also using Peco (Electrofrog) turnouts and PL-10W motors on my layout in progress, and plan on using an old Märklin transformer for turnouts and accessories.
The momentary contact switch is a must for Peco motors, this type of motors requires only a short boost of power otherwise they’ll burn out in a very short time (unlike motors like the Tortoise, which use constant power to press the point rails against the stock rails).
The CDU have nothing to do with the t
What Svein said in his last post, Bob. Definitely AC, definitely momentary contact switch at the panel.
I only have (1) Peco, so I didn’t have to gang them through terminal strips. I used terminal strips, however; just not for that purpose. Here’s a shot of the black and red feeders coming in from the left to the 2-position terminal strip.
The black feeder feeds the black common you see going up to the Peco. The red feeder goes to the 3-position terminal strip. The yellow and green feeders come down from the Peco and connect to that 3-position strip as well.
For the Peco to operate, it must receive power from the black common and either the yellow or green feeder. So at this point you have the makings of a complete circuit (black plus yellow or green), but the Peco won’t operate because those wires are all isolated within the terminal strip. They need to be connected–the black and yellow for the points to be thrown one way; the black and green for the points to be thrown the opposite way. The black’s taken care of; power’s gone directly to the Peco via the black from the CDU through the terminal strip. We now have to power the yellow and green.
They are powered through the toggle. That’s why you see the red, green, and yellow wires leaving the terminal strip and going to the toggle off camera. The red powers the toggle. Throwing the toggle routes power from the red to, say, the green back to the Peco, where it “meets” power from the black common to complete the circuit and throw the points. Throw the toggle the other way, the yellow does the work and the points move in the opposite direction.
I don’t know much about electricity, but I believe the above is correct. If I’ve erred, anyone please feel free to correct me.
Rick Krall
Hi All,
OK, it looks like you all have given me the information I need. Now it comes down to implementing it.
I also have to prepare a facia board for the toggles as well as attach another PL-10. I usually work on several different projects at the same time so it may be a while before I get the turnouts turning.
Thank you all and I’ll be back in touch with the results, one way or the other.
Bob
Greetings,
Well it’s been six weeks and I was sure I’d be posting a success story tonight but it was not to be. I’ve been doing this that and the other all the while working some and thinking about the switch machine.
Today I fired it up and it didn’t even groan or quiver when I worked the toggle. I couldn’t believe it.
I’ve gone over the wiring and can’t find anything wrong. The following crude drawing shows how I wired it. I did use a couple of crimped connectors but I’ve never had any trouble using them before.
Your comments will be greatly appreciated
Bob
The diagram looks correct. Do you have the transformer connected to the input of the CDU (it should have instructions that say which terminals are for the transformer and which go to the toggle switches). And what sort of terminal strips did you use? If they are the kind with pairs of screws with a raised strip between each pair, only the screws across from one another (the short dimension) are connected, the ones next to each other (along the long dimention) are not, unless you jumper the screws on the other side, either with wire or a “bus bar” that they make for the purpose. If you used the type with just a single row of screws, or a row of solder terminals, those are usually already connected so you cna connect the input to one terminal and run multiple outputs off the other terminals.
If everything is wired right, you can check for the CDU being bad by bypassing it, just hook the wires fromt he CDU output to the transformer INSTEAD OF (not at the same time) the CDU. There should be enough power to make the motors snap back and forth, the CDU just gives it more of a positive action plus protects the motor from burnout should the toggle switch stick. Oh yeah, what sort of SPDT momentary toggles are they? Generic ones with a center off, or ones made for the turnouts? Not sure about Peco but many of the ones made by the turnout manufacturers need an extra push to actually make the momentary contact - you flip the lever in the direction you want and then it pushes against the spring-loaded contacts to actually make contact.
Hi Randy,
The terminal strips are the ones with the raised dividers. I have the “fork” type connectors to yoke the terminals togther as needed but for now I’m only hooking up one switch motor.
I bypassed the CDU with power going directly to the terminal strips. Still no luck.
There is power circuit to ( - ) to the switch machine and + to the toggle and the wire with the crimped spade connectore checked out ok. The toggle is generic.
Do you have any other suggestions, and could it be the motor itself?
Well, this might be a little tough (not enough hands) but you could try disconnecting the wires at the switch motor and putting a meter on them, and hold the toggle in one direction or the other and see if you have any voltage (keep the CDU bypassed for this test). If you have power at the wires right at the switch motor, then that validates the rest of your wiring and the problem must lie in the switch motor. If there’s no power there, work back and check at your terminal strips. Pretty much standard troubleshooting - don’t overcomplicate things. If you have power at the source but not at the destination, just move along step by step and check. The problem has to be between the spot you last had pwoer and where it is missing. Electricity is really a simple thing - it needs a complete loop path to work. A break at any point stops things from working.
Or if you have a 16 volt or so light bulb handy - you could connect that instead of the switch motor, the light should be on as long as you hold the switch in the correct position. Again with the CDU bypassed - the burst of power from the CDU would burn out the bulb like a flashbulb. But if you don’t have a meter - see if there is a Hrabor Freight ner you, they have them for $2.99. Even if you don’t understand half the functions on it, the volts and continuity tests alone are worthwhile for model railroading.
It could be that the point motor is defective. It doesn’t take very long to burn them out if power has been applied to them for more than a brief moment. Test it first. Disconnect the transformer from the CDU (unplug it from the wall first!). Disconnect all the wires from the point motor but leave the jumper between the two common lugs intact. Connect one wire from the output of the transformer to the common connection of the point motor. Plug the transformer in again and MOMENTARILY touch the other transformer output wire to one of the “hot” lugs of the point motor. Do the same with the other lug. You should see the linkage move or at least try to move. And you’ll probably see a little spark when you touch the transformer wire to the lug. If nothing happens at all with one or both “hot” lugs, the point motor is probably toast. The only way to tell for sure is to use an ohmmeter set on its lowest range. A good coil should show a few ohms resistance; a burned coil would show an open circuit. Unplug the transformer.
Assuming that the point motor tests okay, you probably have an open circuit somewhere. Make a quick and dirtyi continuity checker by attaching a wire or clip lead to one terminal of a 9 volt battery. Attach one wire of a 12 volt bulb (like a GOW bulb) to the other battery terminal. The two free wires hanging out are the probes of your continuity checker. They both need to have about 1/4" of insulation stripped off them. To check that the continuity checker is working, touch these two wire together. The bulb should light up.
I’m looking at the sketch you posted as I write this. Disconnect both wires from the output of the CDU. Disconnect the two “hot” wires from the point motor. Attach the common wire to the point motor. Clip on lead of your continuity checker to the wire you have marked for connecting to the “-” output of the CDU. Touch the other continuity checker wire to the joined common lugs of the point motor. Lamp should light. If not, move the CC (con
Hi Randy and Bob,
After reading your suggestions sveral times I decided to try Randy’s. At first the big problem seemed to be doing this with out any help, but the light bulb in my brain finally lit up and I easily moved the toggle to the other side of the bench work. Using an alligator clip to hold a probe from the multimeter I had two free hands
In addition to the switch motor I also was attaching an auxilliay switch for an LED on the facia to be hooked up later. It is said that confession is good for the soul so here goes. When checking the wire connections I found I had power going to the auxilliary switch and not the switch motor. With 6 wire leads and only 3 wire colors I had accidentally gotten the leads mixed up.
Needless to say the switch motor is working wll although there is a humming noise when activated
The picture below shows the proper grouping before replacing the turnout.
The execution itself was simple but all did not go smoothly. I had to remind myself several times that I DO like model railroading.
Thanks Randy and to everyone.
Bob
The humming should go away once you hook the CD unit back up. That will give one quick jolt to move the points and then limit the current in case the toggle sticks so the motor won’t burn out.
Randy,
You were right the humming did go away but now there is another mystery.
Using terminal trips I wired a second switchmotor. The first one still worked but not the second one.
After checking the wiring and the connections I bypassed the CDU as you suggested previously and both motors work but with the humming. I can live with the noise but why wont’ the second one work with the CDU??
Your thoughts appreciated.
Happy Railroading
Bob
Recheck the wiring. If one works with the CDU, then there’s no reason why a second switch motor, wired identically to the first, should not also work.
Are your toggles momentary? It sounds like they are not - you need to use momentary toggles to operate solenoid switch motors. If the humming constant? If so, this is exactly the problem - and you are going to quickly burn up the switch motors. This is why it doesn’t work witht he CDU. The first one flips, then the CDU limits the power output, so no humming - but the CDU also cannot recharge so trying to operate the second turnout means it’s trying to run with the very limited current the CDU allows through, and it’s not enough to operate the motor.
This is why I described this as a mystery…
The toggels are momentary.
With the CDU bypassed both motors work but hum as expected.
Reattached CDU and only the first motor worked with no hum
Disconnected #1 motor and #2 flipped back and forth once and that was all.
The only change I made was bypassing the CDU . The wiring has remained constant.
Here is the wiring diagram
Happy Railroading (?)
Bob
Diagram looks correct. Double check to make sure it really is wired the way you drew it. Check the toggles, it could be that #2 isn’t a momentary one, or it’s stuck. I believe the peco motors have two connections for the common feed, one for each coil - are they both wired on both machines? Not sure what else could be wrong, each individual switch motor shoudl be wired like the first one and you should be able to connect any number of those assemblies in parallel with each other to service every turnout on your layout.
If you’re using barrier strips, make sure you’ve got a jumper from one set of screws to the next where you’re using the strip to distribute power from the CDU out to the two separate units.
A CDU takes some time to recharge after activation. This might be as long as several seconds. So, if you throw the first turnout and then the second in quick succession, the CDU might not have recharged enough.
