When Woodland Scenics says to pour Realistic Water at depths not to exceed 1/8 inch, believe it.
I have used Realistic Water before and without any problems. But, each time, I abided by the instructions and limited the depth of the pour to 2/8 inch.
This time around, I designed a lift out section to accommodate a bridge over a river. For various design reasons, the Masonite base of the lift out resulted in a 5/8 inch depth from the surface of the eventual river. After applying plaster cloth and a thin coat of Hydrocal, the depth of the river bed still measured 1/2 inch. What I should have done was to build up the river bed with more Hydrocal to limit the depth of the pours. But, I didn’t.
On November 25, 2012, I made the first 1/8 inch pour. It cleared within 24 hours.
On November 26, 2012, I made the second 1/8 inch pour. It took 48 hours to clear.
On November 28, 2012, I made the third pour. While it slightly exceeded 1/8 inch, the bigger problem was that the first two pours had shrunk, if you will, into the various crevises created by the putty knife used to smooth the river bed of Hydrocal. So, that third pour was probably and nearly 1/4 inch in spots.
Today, the 51st day since that third pour, it is finally completely clear. Over the course of the last 51 days, I could see it gradually clearing. I tried everything. I moved it to a room to lower humidity. I used a floor fan to circulate the air. I used a needle to poke holes to let moisture escape. But, what finally did the trick was exposing it to the sun in a south facing window.
To my knowledge, Realistic Water always clears - - - - eventually. But, if you pour at a depth greater than 1/8 inch, the water quickly develops a cloudiness due to trapped moisture. I even read on another trains forum that one guy waited 8 months for a 1/2 inch pour to clear.
I still have to do one final pour. Oh
