The switch from 8 to four cylinders is so smooth you never notice…unless you happen to be watching the tachometer.
It drops for a just a second, and the in dash information display on your gas mileage starts to climb.
One thing, you must, and this was stressed a lot by the service manager at the dealer where we purchased the car, you must change the oil every 3000 miles or three months…no cheating that extra 3000 miles like you could before.
That, and regular air filter changes are the key to keeping these engines performing correctly.
The MAP sensor can adjust for a slightly dirty air filter, but dirty oil will leave deposits on the locking pin mentioned in the article.
Couple this engine with a electronicly controled transmission, 32 mpg freeway isn’t un reasonable.
The shift points on the tranny are decided by the on board computer( really a series of fault code programmed chips) so depending on the engine temp, outside air temp, and the throttle position, you can get almost instant aceleration.
Although I haven’t been to the local drag strip yet(my wife would beat me senseless) due to the lack of time and spousal fear, I did have a friend with a stopwatch go for a ride with me.
On street asphalt, 80 degrees outside air temp, from a standing start, we got consistant 4.5 second runs 0 to 60mph.
We could not achive consistant results on 0 to 120…the on board system kept adapting to something, and we would get a few quick runs, followed by a slow one.
And this thing handles great…according to the Chrysler people, its a E class Mercedes chassis knock off, with the independent, or “live” rear end, like a Corvette uses.
Body is about 50% plastic, the hood, roof and rear hatch are pressed steel, the front and rear quarters are plastic, the doors are steel frames with plastic.
A lot lighter than I expected, but rides really nice.
Six foot plus passengers can sit in the rear seats, and still have leg
